  3. Info on "oblist"
  • Views 1304
Info on "oblist"
Sutlieff
Sutlieff over 7 years ago
Hi all,
I am debugging some internal legacy SKILL and have come across some code that is using "oblist"
It seems that this is some internal Cadence list (when trying to change it  I am getting:  "*WARNING* (Parser): oblist is a reserved name and cannot be assigned to"
This list, for one particular user, is extremely large so I am curious how this list gets generated.
I am searching for a pop-up window id so I thought I would use hiFormList instead of oblist.
Can anyone shed a bit more light on this list and how it is generated?
Colin
    Hi Colin,
    Code should not use oblist. It's a representation of the contents of SKILL's symbol table - so any time a symbol is created (for a function, a variable, a property, any time that name is used) it ends up in oblast. Because of this, it can't be assigned to because it isn't actually the symbol table.
    If the symbol table gets very large, it could be an indication that there is some SKILL code that is creating pseudo-arrays using variables (rather than using true arrays or hash tables). it's big anyway, but if it's especially big for one user, there may be some customisation doing something bad. Because it can be pretty large, searching it as a list is a bad idea, so your suggestion of using hiFormList is a better idea.
