  3. How to set axis info when plot across design Points
  • Views 17366
sjwprc
sjwprc over 7 years ago
Hi, I have a simple question when I run variable sweep. After sim, if plot across design points, the X-axis is always from point 1 to point N. That is not what I want. E.g., i sweep variable of R, i wish to display X-axis as this "R". How I could set such feature ?
BR
    In that case, don't use Plot across Design Points. Use Plot. Plot across design points is supposed to be indexed by the point numbers.
  • sjwprc
    sjwprc over 7 years ago in reply to Andrew Beckett
    Hi Andrew, do you mean i need manually pick up the point and use "plot", right ? But if I have 100 points, such task can be quite inconvenient...
    Also "plot all" can be one potential way, however if you have many corner, this plots all points once...
    Andrew Beckett over 7 years ago in reply to sjwprc
    Sorry, my mistake. I meant Plot All not Plot. If you want to do it for a subset of points, you could use detail transpose mode, select the range of data you want to plot, and then use Plot. With Assembler, you could filter the results in Detail Transpose mode to just include the corner you want and then select them all and do Plot.
