  3. sim error 5033
  • Views 16893
sim error 5033
Simons
Simons over 7 years ago
when I ran the PVT simulations, many simulations suffer the error. part of job log is shown below.
\o Loading paraplot.cxt
\o WARNING (ADE-3079): Simulation is complete; however, simulation results are currently unavailable.
\o This may be due to file system delay in reading the simulation data.
\o You can specify a timeout value after which results should be made available.
\o For this, set one of the following environment variables in your .cdsinit file:
\o - tryNFSSync (if host system is remote)
\o - tryNFSSyncLocal (if host system is local)
\o If the issue persists, contact Cadence customer support for assistance.
\o
\o *Error* Error ID = 5033
\o *Error* Error Msg = Simulator failed to complete the simulation.
\o
\o
\o
\o
\o
\e IO Error 0 (Success) on Display ":95"
\e Aborting due to fatal X IO error.
\w *WARNING* Process was terminated with SIGABRT signal
\o Local time (crash) Wednesday 20 March 2019, 12:31:31 AM
\o
\o *Info* Received signal SIGABRT.
    Please contact customer support. This needs detailed investigation to understand what might be happening in your environment. From the display number on the X error, you must be using a recent version (IC617/ICADV23 ISR23 or IC618/ICADVM181 ISR1 or later) - but other than that it could be a number of different issues in your environment.
  • Simons
    Simons over 7 years ago in reply to Andrew Beckett
    Thank you !
