  3. Simulation error in ADEXL, runs fine in ADE
  • Views 17418
suhasg26
suhasg26 over 7 years ago
Hi Team,
I face this peculiar problem, whenever I switch to ADEXL to run a bunch of simulations (ADE standalone simulations run fine). The ADEXL simulation errors out saying
ERROR (SFE-874): "input.scs" 43: 63: Unexpected integer "0". Expected close parenthesis. Cannot run the simulation because of syntax error. Correct the error and rerun the simulation.
ERROR (SFE-683): "input.scs" 43: Badly formed parameters statement.
A huge string of parameters (DPAR_* as shown in the below snapshot) are defined by ADEXL which are not part of the intended design variables list (not seen in the netlist parameter set generated by ADE).
And ADEXL sets one of these parameters to 0 (highlighted in green) and flags it as an error.
I did search for this issue on this forum and on google, found no discussion about it. So I'm posting it here.
Any suggestions are welcome. Thanks!
    Andrew Beckett over 7 years ago +1
    I found a small number (2 or 3) reports of this issue in the past (the most recent was a couple of years ago, assuming my search was complete enough), when using the ADE XL parameterisation of certain…
    I found a small number (2 or 3) reports of this issue in the past (the most recent was a couple of years ago, assuming my search was complete enough), when using the ADE XL parameterisation of certain devices. I think it was happening with a particular TSMC PDK, but in both cases we never really received enough information from the customer to identify and resolve the issue.
    So first thing I would suggest is make sure you're using an up to date IC version (e.g. IC617 ISR23 or IC618 ISR2) to see if the issue has been resolved in a later version than the one you're using. If not, please contact customer support because I think we'll need more information to allow us to reproduce and investigate the problem further.
  • suhasg26
    suhasg26 over 7 years ago in reply to Andrew Beckett
    Thanks for the quickest reply, Andrew. appreciate it.
    We are using Virtuoso ICADV12.3 (I don't know where this stands w.r.t the versions you've mentioned)
    But I will contact customer support.
    Thanks again,
    -Suhas
