  3. Alter statement usage for trimming (reelaborate card)
  • Views 15010
Johanny Saenz
Johanny Saenz over 7 years ago
Hi all!
I'm exploring the potentialities of alter statement and I found the re-elaborate option (boolean type), which basically re-elaborates the circuit and trigger the expression evaluation in the circuit.
I want to create a netlist capable of trimming a reference circuit, using in the first part a simulation a DC sweep to calculate through a cross() function the respective trimming word, and then put it in subsequent simulations.
I have tried something like this with no success:
alter1 alter param=trim_val_par value=int(cross(i("R0:1" ?result "dc-dc") 1.8e-6  1 "rising" nil nil)) reelaborate=yes
How I could perform it? Alt
Thanks!
    Andrew Beckett over 7 years ago +1
    You can't do that. You're trying to add a SKILL function in the netlist, and that's not going to work. Potentially you could write some SpectreMDL to do something similar, I think. Regards, Andrew…
