  3. nlSetPcellName for a resistor
  • Views 15293
chqian
chqian over 7 years ago
Hi Andrew:
I had lines below in a libInitCustomExit.il file
;; Adds a random number and time-stamp to the end of the mdoule name of subcircuits.
pcellNameTable = makeTable("PcellNameTable" nil)
procedure( nlSetPcellName( cv paramNames paramValues )
  let( ( tmpStr )
  if( pcellNameTable[cv]
    then
       sprintf(tmpStr "%s" pcellNameTable[cv])
    else
       sprintf(tmpStr "%s_pcell%d%d" cv->cellName random() stringToTime(getCurrentTime()))
       pcellNameTable[cv] = tmpStr
  tmpStr
) ; procedure ** nlSetPcellName **
Here are the netlist it generated from a resistor.
subckt ppolyf_u_pcell1575840381553782469 PLUS MINUS B
parameters segL=2u segW=2u
    R0 (PLUS MINUS B) ppolyf_u l=segL w=segW
ends ppolyf_u_pcell1575840381553782469
// End of subcircuit definition.
R2 (net03 net02 net01) ppolyf_u_pcell890174431553784620 m=1 segL=2u   segW=2u
As you can see: ppolyf_u_pcell890174431553784620 and ppolyf_u_pcell1575840381553782469
are not the same.It will report an error in spectre simulation.
I want to change the code, then it does not add random number but a fix number.
For eg:
R2 (net03 net02 net01) ppolyf_u_pcell_0 m=1 segL=2u segW=2u
Then I can ignore
and include a definition:
subckt ppolyf_u_pcell_0 PLUS MINUS B
So there will be no error when I run spectre.
How can I change the skill code ?
  • chqian
    any one can help about this? thanks.
    Andrew Beckett over 7 years ago in reply to chqian
    If this was urgent, you should contact customer support. The forums are community supported, and even those of us from Cadence on the forums only do this in our spare time. You addressed the original question to me, which rather narrowed the audience for getting an answer, and I was out of the office most of last week and rather busy on the one day that I was available.
    If you just want a fixed number afterwards, simply don't define nlSetPcellName - that's the normal behaviour.
    However, if you wanted to have your random/date related unique number, the issue is that your table for recording the info is using the cellView id which won't necessarily be fixed as you change the top level schematic. So instead you should have your table use the parameter names and values as the key. For example:
      let( ( tmpStr key)
      key=list(paramNames paramValues)
      if( pcellNameTable[key]
        then
           sprintf(tmpStr "%s" pcellNameTable[key])
        else
           pcellNameTable[key]= tmpStr
      tmpStr
    This should then work fine.
  • chqian
    chqian over 7 years ago in reply to Andrew Beckett
    Hi Andrew
    Thanks a lot. I will try your method.
    cqian
