  3. Modelfile not loaded in ADE
  • Replies 18
  • Views 23428
HoWei
HoWei over 7 years ago
I transferred an existing project with PDK into our environment.
In .cdsinit it is set:
  envSetVal("spectre.envOpts" "modelFiles" 'string "/model_libraries/models/lvt_mos.scs;TT")
When verifying in the CIW via
 envGetVal("spectre.envOpts" "modelFiles")
I see it is set properly.
But when opening ADE and creating a netlist, it does not include this modelfile. It also does not show the modelfile in the ADE modelfile-popup-windows - its just empty.
This not only for existing cells, it is also for newly created cells.
WhenI select the modelfile in the ADE modelfile-popup-window, it is included in the netlist.
How can I make it to include the modelfile ?
What does prevent the modelfiles to be loaded ?
    Andrew Beckett over 7 years ago in reply to HoWei
    HoWei said:
    Is there a way to tell existing states, that they shall use the model-files defined by "envSetVal("spectre.envOpts" "modelFiles") automatically - without unset/set spectre in the ADE ?
    T...here is an option when you load a state to not update the models from the state: envSetVal("asimenv.loadstate" "modelSetup" 'boolean nil)
    This only works with ADE L though (I think).
  • HoWei
    HoWei over 7 years ago in reply to Andrew Beckett
    I am not sure, but I this sounds like I want to set this option to "true" to get it updated, right ?
    If its only for ADE-L this does not help, but I will give it a try ....
    No. If you set it to t, it means that when you load a state it will use the model setup information stored in the state. If you set it to nil, it will use the "default" setting and not override it with the value saved in the state.
    You can see the same thing that if you open a new ADE L session, and then use Load State, the "model setup" checkbox will be turned off when you have the env var set to nil. The default value of the env var is t.
  • HoWei
    HoWei over 7 years ago in reply to HoWei
    You are right - it only works for ADE-L but not for ADE-XL.
    This means I would need to unload/load the spectre-simulator in all the ADE-XL tests  ?
    No GUI-button to click to load the "default" state ?
    No. It's a bit of an odd thing to do...
    I've got some info from ST that I can send you - however, I don't think I should post it in a public forum so I'll email it to you directly.
  • HoWei
    Okay, thanks  - it would be interesting to see their recommendations.
    But I think the above problem is independent from PDK - its a general virtuoso issue if you have existing ADE-XL states and want to change the paths of the model-files.
    Thanks for your quick help !
    ADE Assembler has the ability for you to set the model setup in one test, and then apply it to all tests (there's an apply to all button). That's not in the older ADE XL because new developments are not going into the older tools in "sunset" mode.
    You also would typically use the corners setup in ADE XL/Explorer/Assembler anyway rather than the models in each test, so that is another way of unifying them.
  • HoWei
    Yep, that is true - at least I know now what the problem is and we will get around it either the one way or the other. The ST comments are very helpful and I have to check what is implemented in our setup.
    Best regards
    Holger
