  3. How do I parameterize analoglib.ipwlf's cdf parameter"PWL...
  • Subscribers 133
  • Views 1234
How do I parameterize analoglib.ipwlf's cdf parameter"PWL file name"
Zest
Zest over 7 years ago
The situation is different PWL file for  different corner
I want to  parameterize analoglib.ipwlf's cdf parameter by fill "FILEPATH"/VAR("FILEPATH")/VAR(FILEPATH)
then I set variable combine with corner setting
But now all the phrase above does not work
The CIW log is Uable to open waveform file '"FILEPATH'
