  3. how to short circuit in layout for analogLib\iPRB kind behavioural...
  • Subscribers 133
  • Views 3405
how to short circuit in layout for analogLib\iPRB kind behavioural cell
DavidLou
DavidLou over 7 years ago
hello experts,
I noticed from other post that lxRemoveDevice  which can remove devices and short in the process. but that's some script to process while netlisting. can we set some property in the symbol like "nlAction" = ignore as basic/noConn. is there similar user property we can set to get remove the current cell and short the terminals when layout/lvs/drc, etc?
thanks,
David
    Hi David,
    It's not a "script to process while netlisting". It's the property you use to tell either VLS XL or the netlisters (if you've enabled it). The documentation explains how to use them - search for lxRemoveDevice.
    nlAction=ignore won't work because that just tells the netlist to omit the device, and gives no information about how to short the terminals.
  • DavidLou
    DavidLou over 7 years ago in reply to Andrew Beckett
    yup, putting lxRemoveDevice as User Property works.
    thanks Andrew,
    David
  • Pirate King
    Pirate King over 6 years ago in reply to Andrew Beckett
    apologies for replying to this but does lxRemoveDevice only work for layout XL and not L?
    Lance
    Andrew Beckett over 6 years ago in reply to Pirate King
    Hi Lance,
    What would it mean in VLS L? VLS L doesn't care about connectivity...
    It's used by VLS XL but can also be honoured by the auCdl netlister for LVS purposes.
