  3. how to setup and run multiple STB simulation in a single...
  • Subscribers 136
  • Views 20906
how to setup and run multiple STB simulation in a single state
Pic Hao
Pic Hao over 7 years ago
hi there, i had a question about STB simulation. Background is:
-- I had a switch cap integrator.
-- the amplifier in integrator is gain boosted
-- so for STB simulation, I need to check "main loop", "p-side gain boost loop", and "n-side gain boost loop". that's say, at least 3 STB simulations
-- what I'm doing now is: run transient simulation first, and launch STB simulation at specific time by set "output --> actimes(e.g. 100uS) --> acnames (STB)"
Now it seems:
-- only 1 STB analysis can be added in adel
-- then I have to setup 3 adel states, and run transient simulation 3 times (which is a waste of time), with each simulation stopping at the same time and launch different STB analysis (for main_loop/p_boost_loop/n_boost_loop)
My question is:
-- can i add 3 STB analysis in adel simultaneously?
-- So I only need run transient 1 time, and launch 3 STB analysis one by one.
-- Benefit is: only 1 transient is required for 3 STB analysis. save computer time.
Thanks a lot.
  • Dimitra Papazoglou
    Dimitra Papazoglou over 7 years ago
    Hi Pic Hao,
    Have a look into the following article:
    How to run multiple analysis of the same type using Analog Design Environment.
    Dimitra
  • sjwprc
    sjwprc over 7 years ago in reply to Dimitra Papazoglou
    i think the best way is using assembler/adexl, you could make more tests as you want.
