  3. Issue with multiple QRC runs
  • Views 15232
Suryansh Singh
Suryansh Singh over 7 years ago
Hello ,
I am trying to write a script to give multiple Quantus QRC runs.
So  I have done something like :
for file in <list_of_command_files>
   qrc -cmd file -log_file <file>.log &
Now the issue that I see is that QRC fails for some of the cases in the command file(which is also not very uniform, sometimes it does not even fail).
I see the following message in the qrc log :
[ERROR] Could not read temporary file: /tmp/<somefile>
ERROR (LBRCXM-609): Bad return status from RCX run. 0x200
INFO (LBRCXM-709): ***** Quantus terminated abnormally *****
I checked for the error code but this problem is not mentioned there.
I would also like to tell that I am using the option "-temporary_directory_name"  in my command files and its value is different for each run so I dont understand why is qrc using this /"tmp" directory. I also observed if I add bsub command for execution of qrc, qrc did not fail.
Am I missing something over here ?
Regards
Suryansh Singh
    Hi Suryansh,
    You've not really given enough information. I do know there are some files that get written into /tmp regardless, but I'm not sure why it would fail (especially as the "<somefile>" bit is not very specific.
    Please contact customer support.
  • Suryansh Singh
    Suryansh Singh over 7 years ago in reply to Andrew Beckett
    Hello Andrew,
    Thanks for your response. I did not mention the files as it was some local netlist post-processing script. I figured out what was going wrong.
    The issue was that the Post-processing script created some files during its execution and later removed them. The file created had the same name across the multiple QRC runs and were created in /tmp directory. Now since the runs were all in parallel, they could use this file and the "faster" run would remove the file while the "slower" run was still using it.
    I could think of adding a time stamp to the names of these files as a solution.
    Regards
    Suryansh Singh
