  3. Print spectre parameters
  • Views 17148
MatthewLove
MatthewLove over 7 years ago
In spectre model files there are parameters in the form:
parameters
+ x = y
+ a = b
+ m = n
Is there a way of printing out the value of these parameters?
    Andrew Beckett over 7 years ago +1
    Yes. In ADE, go to Outputs->Save All. In the Save Circuit Information Analysis section (there's a table) in the <Click to Add> field enter a name (e.g. allparams) and then set the What column to allparameters…
    Yes. In ADE, go to Outputs->Save All. In the Save Circuit Information Analysis section (there's a table) in the <Click to Add> field enter a name (e.g. allparams) and then set the What column to allparameters and the where column to file. You can then give a filename if you want (a local file name will be written into the netlist directory). This will then give the evaluated values of all top level parameters plus the subckt parameters for each hierarchical instance in the design.
  • MatthewLove
    MatthewLove over 7 years ago in reply to Andrew Beckett
    Thanks Andrew.
