  3. Error in running HSPICE NETLIST using cadence virtuoso ADE...
  • Subscribers 136
  • Views 20760
Error in running HSPICE NETLIST using cadence virtuoso ADE L
Chandu D
Chandu D over 7 years ago
I am trying to go through a tutorial 'FreePDK15:Analog Artist with HSPICE' from the following link.
https://www.eda.ncsu.edu/wiki/FreePDK15:Analog_Artist_with_HSPICE#Saving_the_HSPICE_Netlist
Once I save the generated HSPICE NETLIST, as inv.sp, I get an error with the following text in CDS.log window and a dialog box opening that says 'hspice: command not found'.
Can anyone suggets me how to solve the problem? Thanks in advance
Netlisting Statistics:
Number of components: 6
Elapsed time: 1.0s (6.00/s)
Errors: 0 Warnings: 0
...successful.
compose simulator input file...
...successful.
start simulator if needed...
...successful.
*Warning* The version of the Hspice simulator that you are using may not
support the generation of PSF output on Linux. If you are having
trouble viewing simulation results, please contact Hspice customer
support to identify the version that supports this capability.
simulate...
INFO (ADE-3069): Errors encountered during simulation. For more information, see the log files
accessible from the Simulation -> Output Log menu.
    This means you do not have the hspice executable in your UNIX path, and so it cannot invoke the simulator.
    It means your environment is not set up correctly - in order to run HSPICE you need to have the bin directory from the HSPICE installation in your UNIX path.
  • Chandu D
    Chandu D over 7 years ago in reply to Andrew Beckett
    Thanks Andrew
