  3. VIVA calculator dnl&inl
  • Views 4257
Simons
Simons over 7 years ago
I try  expression below. It could not work.
dnl(abs(dac_out_DC) 0.625m  ?mode "auto"  ?crossType "rising" ?delay 0.0 ?method "end" ?units "lsb" ?nbsamples (256/VAR("dac_step")))
but it works when I use dnl(abs(dac_out_DC) 0.625m ?mode "auto" ?crossType "rising" ?delay 0.0 ?method "end" ?units "lsb" ?nbsamples 256).
The difference between these two expression is the "bnsamples" argument. Do you know why?
    What happens when you use the first expression in the calculator? What does VAR("dac_step") give if you hit the plot/eval icon in the calculator?
  • Simons
    Simons over 7 years ago in reply to Andrew Beckett
    Thanks for your response!
    1. when  use the first expression in the calculator, the CIW shows information below:
    expression evaluation failed: dnl(abs(dac_out_DC) 0.000625 ?mode "auto" ?crossType "rising" ?delay 0.0 ?method "end" ?units "lsb" ?nbsamples 256/VAR("dac_step"))
    ("error" 0 t nil ("*Error* drfGetWaveformYVec (DRL-18): argument not a valid srr waveform interface object 2.768375e-05"))
    2. VAR("dac_step") could be evaluated to 1.
    Andrew Beckett over 7 years ago in reply to Simons
    That sounds as if the input waveform isn’t actually a waveform but a single number. Could you contact customer support? I think we’ll need to see your data and setup to properly diagnose the problem.
    Kind Regards,
