  3. RE: transient simulation accuracy
  • Subscribers 133
  • Views 15703
Kifah
Kifah over 7 years ago
Hi Andrew
I'm using transient simulation to draw the output wave forms of different LNAs, I know that Accurcy Defaults ( consevative, moderate and liberal ) manage the resolution of the wave form, but my question is how I can manage the number of sampels per period.
for example:
for frequency 1G Hz, I need to see wave form with 1000 samples per 1n sec.
Sincerely,
Kifah
    Hi Kifah,
    This didn't appear to be that related to the thread which you'd appended to (the Forum Guidelines ask you not to post on the end of old threads) so I split it into a new one.
    First thing I should say is that just because a waveform doesn't have a certain number of points in the period or doesn't appear smooth doesn't mean it's not accurate - what you are getting is the points that were simulated - the waveform tool just joins those points (so it's the points that are accurate, not the lines).
    However, if you want to force a certain number of samples (for some post-processing reason, such as performing a DFT/FFT) then you could set the strobeperiod option on the transient options form. If you set this to 1p (1ps) then it will ensure that the output database is generated at 1ps intervals. Note that the simulator will actually solve at these points (plus any others it needs to) so the results are not interpolated if you do this.
  • Kifah
    Kifah over 7 years ago in reply to Andrew Beckett
    I tried it and its worked.
    Thanks alot,
    Best regards,
    Kifah
