  3. use outcome of one sim (w. post processing) as the input...
  • Subscribers 133
  • Views 15131
use outcome of one sim (w. post processing) as the input of next sim
Karev11
Karev11 over 7 years ago
I have a case as below:
sim1: sweep code1 and based on output1 value (w. a threshold), decide which code1 to use
sim2: set code1 to be the one chosen from sim1, and sweep code2.
I've been doing this manually for a long time, and wonder if either adexl or assembler can combine and automate these two sims?
thanks,
Kevin
    Hi Kevin,
    This can be done with Run Plans in ADE Assembler. Take a look at this RAK: Techniques for Simulating Calibrated Circuits with Virtuoso ADE Assembler
  • Karev11
    Karev11 over 6 years ago in reply to Andrew Beckett
    Thanks Andrew! it works very well!
