  3. "Assura has not been installed in this hierarchy" Error
  • Views 4261
nokta
nokta over 7 years ago
Hello All,
When I open Layout XL I receive this message from CIW
*WARNING* dlopen: /eda/cadence/2018-19/RHELx86/ASSURA_04.15.115/tools.lnx86/assura/lib/64bit/libavview.so: /eda/cadence/2018-19/RHELx86/ASSURA_04.15.115/tools.lnx86/assura/lib/64bit/libavview.so: undefined symbol: _ZN7QObject13connectNotifyEPKc
*WARNING* Failed to open shared object file /eda/cadence/2018-19/RHELx86/ASSURA_04.15.115/tools.lnx86/assura/lib/64bit/libavview.so
*WARNING* (LE-104272): Assura has not been installed in this hierarchy.
Than I check versions of Assura and IC Design Envirmont
$which assura
/eda/cadence/2018-19/RHELx86/ASSURA_04.15.115/tools.lnx86/bin/assura
$ assura -v
Assura (R) Physical Verification Version av4.1:Production:dfII6.1.7-64b:IC6.1.7-64b.500.12
Release 4.1_USR5_HF15
Copyright (c) Cadence Design Systems. All rights reserved.
@(#)$CDS: assura_64 version av4.1:Production:dfII6.1.7-64b:IC6.1.7-64b.500.12 05/03/2018 21:53 (sjfhw625) $
sub-version 4.1_USR5_HF15, integ signature 2018-05-03-2129
run on server.adress from /eda/cadence/2018-19/RHELx86/ASSURA_04.15.115/tools.lnx86/assura/bin/64bit/assura on Mon May 6 19:37:15 2019
No mcf file specified
***** Assura terminated abnormally *****
and when check IC design version from help menu, it is IC6.1.8-64b.83
This situation occurs after update cadence tools. Here is also part of my .cshrc file
setenv CDS_ASSURA /eda/cadence/2018-19/RHELx86/ASSURA_04.15.115
setenv ASSURAHOME $CDS_ASSURA
setenv SUBSTRATESTORMHOME $ASSURAHOME # For Assura-RF
setenv LANG C
setenv PATH "${PATH}:${CDS_ASSURA}/tools.lnx86/bin"
setenv PATH "${PATH}:${CDS_ASSURA}/tools.lnx86/assura/bin"
setenv PATH "${PATH}:${CDS_ASSURA}/tools.lnx86/dfII/bin"
setenv PATH "${PATH}:${SUBSTRATESTORMHOME}/bin"
#setenv ASSURA_AUTO_64BIT ALL
alias help_cds_assura '$CDS_ASSURA/tools/bin/cdnshelp &'
I am not sure are they relevant but I am also reviecing errors at the begining of IC
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
Can any one help me about
    Andrew Beckett over 7 years ago +1
    You're using IC618 but trying to use a version of ASSURA built for IC617. See How to verify the correctness of the Assura environment configuration after installation if Assura menu does not appear in…
    See How to verify the correctness of the Assura environment configuration after installation if Assura menu does not appear in the layout
    On downloads.cadence.com you'd need to download the ASSURA41 build for IC618 - for example ASSURA04.16.001, Version: ASSURA_41USR6_OA-618
  • nokta
    nokta over 7 years ago in reply to Andrew Beckett
    Thank you
