  3. "readns" cannot read state-file in DC Corner Simulation
  • Views 1615
Chenbt
Chenbt over 7 years ago
I have some trouble with DC convergence problem. I add a state-file using "dc-->Options-->readns" and make it converge while I can see the reading procedure in the output Logs.
But when I started a Corner Simulation, I found that simulation cannot converge and in the Output Logs there was no reading procedure. I thought it's because the Corner Simulation ignored my settings in "dc-->Options-->readns". So how to deal with this problem, I really hope someone can help me with that, -_-
I'm working with ADEXL in 6.1.5.
Chen
    I don't see any reason why the options on a dc analysis should be ignored in ADE XL when simulating over corners - I've never seen this happen before, even with the really old version that you're using...
