  3. Simulation crashed - Killed by user
  • Views 5145
BaaB
BaaB over 7 years ago
This simulation suddenly crashed and there was a line saying that "Killed by user".
I didn't kill it myself. Does this mean that someone actively killed it?
    Maybe you have CPU time limits in your environment? If you're using a queuing system (like LSF) you might need to check the queue setups - if simulating directly, see what the "limit cputime" command says (if using csh), or "ulimit -t" says if using bash/ksh.
  • BaaB
    BaaB over 7 years ago in reply to Andrew Beckett
    I just checked that and it said "unlimited".
  • Dimitra Papazoglou
    Dimitra Papazoglou over 7 years ago
    If you use ADE-XL or Assembler, The "Killed by user" errors might also appear in case you are firing up more than 1 runs with "Reassign immediately for new run" option enabled in 'Job Policy Setup' form and have set "Run in" option from Series to Parallel in 'Run Options' form.
    In this case, once the second run is fired up then some of the already running jobs in the first run are getting killed forcing spectre to get killed as well (spectre.out reports "Killed by user") and then are reassigned to the new(second) run. When those jobs become available again, then the sim for the "incomplete" points of the first run (where spectre was killed) re-starts again.
    To avoid such cases you need to enable "Wait until currently running points complete" instead of "Reassign immediately for new run" in 'Job Policy Setup' form.
    Not sure if your case is the same but thought it's worth checking.
    Regards
    Dimitra
  • BaaB
    BaaB over 7 years ago in reply to Dimitra Papazoglou
    Thanks. I am using version  IC6.16-64b.101 and not aware of 'Job Policy Setup' form. I did a quick search and saw that it is in ADE XL. Where can I change it in ADE L?
    Dimitra Papazoglou over 7 years ago in reply to BaaB
    What I'm describing above is for ADE-XL and ADE Assembler. The idea of reassigning job for new runs is not implemented in ADE-L as far as I know.
    So your issue is not the case I'm describing.
    If the error is seen often without user killing simulation then I'll suggest you to contact Cadence Support (support.cadence.com) so someone can take a closer look. If you are from university then you should ask your professor how you can get support, usually it's through Europractice.
    Dimitra
