  3. Is there any shortcut, bindkey to bring up CIW window quickly...
  • Views 16965
Is there any shortcut, bindkey to bring up CIW window quickly?
BaaB
BaaB over 7 years ago
Is there any shortcut, bindkey to bring up CIW window and Library Manager quickly?
(version  IC6.16-64b.101)
    You can easily define one - the command that you'd put in the bind key string would be:
    "hiDeiconifyWindow(hiGetCIWindow()) hiRaiseWindow(hiGetCIWindow())"
    This copes with it being minimised as well as being hidden.
  • BaaB
    BaaB over 7 years ago in reply to Andrew Beckett
    Is this the correct command for CIW windows?
    hiSetBindKey("Schematics" "<Key>F3"  hiDeiconifyWindow(hiGetCIWindow()) hiRaiseWindow(hiGetCIWindow())")
    Also how would you do it for Library Manager?
    I don't know how to write  bindkey command yet.
    Andrew Beckett over 7 years ago in reply to BaaB
    Yes, that would do it for schematic windows. You can’t define bindkeys for the library manager.
  • NickA
    NickA over 7 years ago in reply to BaaB
    Try this...
    hiSetBindKey("Schematics","CTRL<Key>l", "ddsOpenLibManager()")
    Andrew Beckett over 7 years ago in reply to NickA
    Ah, just realised the question was potentially ambiguous. I thought it was asking about whether you could define a bind key for the library manager which raised the CIW; NickA posted a solution to open the library manager from the schematic (which is a reasonable thing to do, and is perfectly possible) - I didn't interpret the question that way, but if that's what BaaB meant, then that's the answer.
