  3. Exporting the waveforms from Cadence ADE to plot it in ...
  • Views 17141
Exporting the waveforms from Cadence ADE to plot it in Mathlab
NorNand
NorNand over 7 years ago
I need your help please to export my waveform results from Cadence ADE simulator to plot it in Mathlab. Is that is possible?
Thank you
    Andrew Beckett over 7 years ago +1
    Assuming by "Mathlab" you really mean MATLAB from the MathWorks, then you can export waveform results from ViVA graphs (Right Mouse->Send to->Export from the graph, and pick "Matlab" as the Files of Type…
    Assuming by "Mathlab" you really mean MATLAB from the MathWorks, then you can export waveform results from ViVA graphs (Right Mouse->Send to->Export from the graph, and pick "Matlab" as the Files of Type), or in ADE Explorer/Assembler there's a direct integration of Matlab within ADE (you didn't say which ADE you're using, or which version - please read the Forum Guidelines before posting). There are rapid adoption kits on that and also videos on use of the integration on support.cadence.com
  • NorNand
    NorNand over 7 years ago in reply to Andrew Beckett
    Hi Andew,
    Thank you for your answer,
    I am using Cadence Virtuoso IC6.15 and spectra simulator version 11.1
    Regards
