  3. Cadence Liberate for characterizing
  • Replies 8
  • Views 19825
fengye
fengye over 7 years ago
Recently, I use  Cadence Liberate to characterize the standard cell. Some novel error occurs, shown as the follow
ERROR reminder:
Did anyone meet with this type error? Hope someone can help me!
Thanks a lot!
  • fengye
    The most amazing is this error won't occur with the usage of UMC technology. This error occurs with the usage of TSMC technology models.
    Andrew Beckett over 7 years ago in reply to fengye
    This article gives some info on how to debug this problem: Liberate prompts SYSTEM ERROR - could not execute command
    If that doesn't help, please contact customer support.
    Regards.
  • fengye
    fengye over 7 years ago in reply to Andrew Beckett
    Thanks for your suggestion ! After I debug just as the solution, there is no errror accuring in the spectre output log file but some warning.
    Warning from spectre during circuit read-in.
    WARNING (SFE-1134): "/tmp/altos.VLSI-01.T20190522180417997308S0059505.0/sim.sp" 300: Unexpected value '1' - expected option name: skipped.
    Warning from spectre during hierarchy flattening.
    WARNING (SFE-30): "/tmp/altos.VLSI-01.T20190522180417997308S0059505.0/sim.sp" 300: .options: `brief' is not a valid parameter for an instance of `options'. Ignored.
    WARNING (SFE-30): "/tmp/altos.VLSI-01.T20190522180417997308S0059505.0/sim.sp" 300: .options: `runlvl' is not a valid parameter for an instance of `options'. Ignored.
    Could you give me more suggestions?
    Thanks a lot !
    fengye
    Hi fengye,
    Yes, contact customer support as I suggested earlier. I'm out of the office this week (and I'm not a Liberate expert anyway), so my opportunity to investigate is rather limited. By contacting support, you'll get to somebody with the correct product expertise.
  • fengye
    Thanks for your suggestion, I will contact the customer support as you suggested.
    Regards!
    fengye
  • fengye
    Hi, Andrew,
    I'm happy to tell you that this error has been solved when I delete "define_leafcell -extsim_model -type nmos_soi -pin_position {0 1 2 3} { nfet lvtnfet }". There is no probelm with spectre. Thanks for your suggestions.
    Could  you give some suggestions about the settiong of the constraint template for Dflipflop? Because I meet this type error
    ERROR (LIB-304): (char_library): Constraint search for arc BALLOON_SIM, CK, r, NRESTORE, f, hold_rising fall_constraint (D * !SAVE) probe=Q failed. This cell is now marked as failed and should not be used. Modify your define_arc command and rerun.
    ERROR (LIB-304): (char_library): Constraint search for arc BALLOON_SIM, CK, r, NRESTORE, f, hold_rising fall_constraint (!D * !SAVE) probe=Q failed. This cell is now marked as failed and should not be used. Modify your define_arc command and rerun.
    ERROR (LIB-52): The constraint search failed to find a solution within the search range for arc of cell:'BALLOON_SIM', r_pin:'CK', r_pin dir:'r', pin:'NRESTORE', pin dir:'f', type:'setup_rising fall_constraint' when: (!D * !SAVE), GLITCH_PROBE. This cell will be marked as failed and the constraint data will be set to: 1.0 (see constraint_failed_value). To debug, review the saved simulation results for deck: setup_30. Possible causes include: 'constraint_glitch_peak' too small; 'constraint_check_final_state_threshold' too large; estimated search range too small (see constraint_search_bound). Modify the constraint parameters and rerun.
    ERROR (LIB-55): No valid vectors were found for the user provided define_arc for arc of cell:'BALLOON_SIM', r_pin:'CK', r_pin dir:'r', pin:'NRESTORE', pin dir:'f', type:'hold_rising fall_constraint' when: (D * !SAVE). To debug, review the saved simulation results for deck: hold_36. Review port direction and vector values. Review spice deck(s) for valid delay measurements.
    ERROR (LIB-55): No valid vectors were found for the user provided define_arc for arc of cell:'BALLOON_SIM', r_pin:'CK', r_pin dir:'r', pin:'NRESTORE', pin dir:'f', type:'hold_rising fall_constraint' when: (!D * !SAVE). To debug, review the saved simulation results for deck: hold_40. Review port direction and vector values. Review spice deck(s) for valid delay measurements.
    In my template tcl, for VDD=1.1V, my setting is
    define_template -type constraint \
    -index_1 {0.00240103 0.170448 0.760328 } \
    -index_2 {0.00240103 0.0861582 0.380164 } \
    constraint_template_3x3
    I hope your reply when your're in your free time.
    fengye
    Fengye,
    As I said earlier, I am not a Liberate expert. I know enough to understand the principles, but not enough to answer such questions without it involving a lot of experimentation and research. I would normally defer such questions to Guangjun in my team (who often answers here for Liberate questions) but he is away for at least another week.
    As I suggested before, your best option would be to ask this kind of detailed question to customer support.
  • fengye
    I know what you mean, thanks a lot.
    fengye
