  3. what is the difference between "parseAsCEL no" and "parseAsCEL...
  • Views 3010
what is the difference between "parseAsCEL no" and "parseAsCEL don't use"?
zssfred
zssfred over 7 years ago
subject says it all.
    There is no difference. If you say "don't use" it doesn't explicitly set parseAsCEL and so it would be the default (which is "no"). If you set it to "no", it does the same thing.
    It's a bit confusing, I agree...
  • zssfred
    zssfred over 7 years ago in reply to Andrew Beckett
    It is little bit weird. Before I posted here, if I single-quoted the value like 'value', and if I selected "don't use", the auCdl netlist will keep the quote and I selected "no", the auCdl netlist will strip the quote.
    But after I read the post, the quote is always there no matter "don't use" or "no". Yes, they have no difference now. The interesting thing is the pPar() is always parsed even in "no" mode. Say, we have defined parameter like a=pPar(b)+pPar(c), the netlist is always like a=b+c.
    Thanks.
    Fred
    Andrew Beckett over 7 years ago in reply to zssfred
    That's partly because pPar() is not entirely "CEL" but this is slightly surprising. It might depend upon the netlister (auCdl may be different from spectre, for historical reasons for example). It may also depend on the parseAsNum setting.
    I suggest you contact customer support if you need this exploring in more detail (I don't have the bandwidth at the moment to research and find out the answer, sorry).
  • zssfred
    Sure. Already, opened case.
    Thanks.
    Fred
