  3. Is there a way to customize the netlist fom subckt netlister...
  • Subscribers 126
  • Views 2061
Is there a way to customize the netlist fom subckt netlister(like ansCdlSubcktCall and ansCdlSubcktCallExtended)?
zssfred
zssfred over 6 years ago
Subject says it all.
Thanks.
Fred
    I don't know what you're actually asking here. What is a "subckt netlister"? The customisation possibilities for these two functions are described in the documentation, and they are driven by certain fields in the auCdl simInfo in the CDF.
  • zssfred
    zssfred over 6 years ago in reply to Andrew Beckett
    Andrew Beckett said:
    "subckt netlister"?
    It is ansCdlSubcktCallExtended or ansCdlSubcktCall. We can just define the parameters in simInfo. But how can we customize the way these parameters being printed?
    Thanks.
    Fred
    Andrew Beckett over 6 years ago in reply to zssfred
    Since you have asked exactly the same question to customer support via case 46361489, I won't duplicate the work of my colleagues.
    Please do not post both to the forums and to customer support - it just causes duplication of effort which is not very efficient when we all have limited resources.
  • zssfred
    Andrew,
    Understand. Coz, I can get faster help here, I will raise it here then opening case next time.
    Thank you so much!
    Fred
    Hmm. Not sure that's quite the point. The community forums are just monitored by a few of us in Cadence in our spare time (it's not part of my role at Cadence to answer here, for example), and should not be seen as an alternative to customer support, which is tracked and is the required route if (for example) a change request is needed for the software.
    There's no guarantee of an answer on the forums - you may end up waiting for ever... you might get a quick response, but you might not get a response at all!
  • zssfred
    whoops! It is unbelievable that you can achieve such great technical help and discussion just in your spare time. For me, I always get prompt and smart solution here. I don't know how to
    comment on your paid support here. hahaha ;-) Anyway, understand and thank you!
    Fred
