  3. A divide by zero exception has occurred
  • Views 18060
BaaB
BaaB over 7 years ago
I got the warning below. M4 is a transistor and when I followed the hierarchy  I couldn't find the parameter "r1".
What's it?
WARNING (ASL-6236): "Internal (bsource)" 0: I529.I4.M4.r1: A divide by zero exception has occurred. Therefore, zero will be replaced with a small non-zero value of 1e-5.
(version  IC6.16-64b.101)
    Look in the spectre netlist (input.scs) for the MOS device M4. Find out what the "model" name of the transistor is. Most likely this model is actually a subckt defined within the model files incuded via Setup->Model Libraries so look through those files to find the definition of the subckt. Within that there's probably an instance called r1 which is a bsource, and that has some kind of expression which has a divide by zero in it for some reason - maybe inspecting it will reveal why.
    This is a bit of a guess given that i know nothing about what technology you're using, but it's a reasonably likely setup.
  • BaaB
    BaaB over 7 years ago in reply to Andrew Beckett
    Thanks! I found that but the expression is really complex. I think I used the same transistor in another circuit and it didn't have this problem.
    M4 (net25 net023 VDDH VDDH SUB) pa8_g5a_nbl_mac l=300n w=20u \
    ad=2.486e-11 as=9.6e-12 pd=26.52u ps=41.92u nf=2 dti=0 multi=2
    and this is for r1:
    r1 (n1 n11) resistor r=(rdc0*wfac_res+(rd0 * exp (rd1* v(n2,n3)) * tanh(pow((1e-5+abs(v(n1,n3))),vdeff)/vdmr)
    + * (1+rdb0*v(n4,n3)) * rd_weff) *drd) *((v(n1,n3)<0)?1:0)+ (rdc0*wfac_res+(rd0rev
    + * tanh(pow(1e-5+abs(v(n2,n1)),vgeffrev)/vgmrrev) * tanh((1e-5+abs(v(n1,n3)))/(vsmr0rev
    + * exp(vsmr1rev * v(n2,n1)))) * rd_weff_rev)* drd )* (1-(v(n1,n3)<0)?1:0)
    + m=multi*nf
    Andrew Beckett over 7 years ago in reply to BaaB
    Without knowing the context of the message, this might be a warning that appears temporarily during calculations but doesn't adversely affect the final result.
    I'd first recommend ensuring that you're using a recent version of spectre (I suspect not, given that you're using a rather elderly IC version). If the problem just shows up at the beginning, it's probably OK - but any concerns you have should be raised with the foundry who supplied the model files.
