  3. putprop error running Quantus with Calibre inputs
  • Subscribers 133
  • Views 7341
ArturS
ArturS over 7 years ago
I have encountered following error running Quantus with Calibre inputs gui after specifying input data and pressing Ok:
*Error* putprop: first arg must be either symbol, list, defstruct or user type – nil
The full CIW output is following:
«Quantus Run: Loading Technology Data. Standby...
Loading tech rule set file : /home/serazetdinov/umc2018/generated/QRC/techRuleSets
*Info* Autodetect: Calibra db is hierarchical
*Error* putprop: first arg must be either symbol, list, defstruct or user type – nil».
The fields of Quantus (Calibre) Interface form are filled as follows:
The Calibre query utility was used and required query outputs were generated (i.e. SUBSTRATE_COMPx3.gds.map, SUBSTRATE_COMPx3.agf, etc – according to “Quantus QRC Extraction Users Manual 18.10: Running Quantus QRC with PVS and Calibre inputs”). Calibre query direct field points to the folder with these query outputs.
Run name was choosen same as layout cellview name (SUBSTRATE_COMPx3). In that case Layer Map File field is filled automatically and was not changed manually (SUBSTRATE_COMPx3.gds.map – file is located in query output directory).
Quantus Tech Lib field specifies the location of assura_tech.lib file (in which technology umc180 is defined with it’s qrcTechFile path location). qrcTechFile, procfile and p2lvsfile were created with Techgen from the ict tech file.
Technology pull-down menu is filled automatically as it’s specified in assura_tech.lib file.
Prop fields were not changed.
I’ve used Virtuoso 6.1.8, Techgen 18.2.10-s210 and Quantus 18.21.
If anyone has fixed such an error or knows how please help
    I did a quick search and didn't see anything quite like this (unfortunately the error message is a low level SKILL error and so doesn't reveal a great deal about the root cause). I think you'll need to contact customer support to debug this further.
