  3. pin placement Level-1 pins
  • Views 16251
DaveHelsen
DaveHelsen over 7 years ago
I'm trying to move the pins off Level-1 to the same position as the top-level.
When I start the Pin Placement, and select the soft-block I see the pins...
Now the when I want to move to edge "Top-level route" I get an error in the ciw
error = "the option to snap level-1 pins to top-level routes is disabled. Enable the option and try again"
Can someone tell me were to enable this?
kind regards
Dave
    Andrew Beckett over 7 years ago in reply to DaveHelsen +1
    I believe in IC617 this requires access to a pre-release capability which needs a special incubation license to enable. Might you be able to try with IC618 to see if it's resolved there? Regards, Andrew…
    Hi Dave,
    From a very quick search, this is something that may be resolved by using IC618 (or ICADVM181) rather than IC617/ICADV123. Which version are you using?
  • DaveHelsen
    DaveHelsen over 7 years ago in reply to Andrew Beckett
    IC617, you think it's an error / missing function. I can check with CAD if we can have a test case for this.
  • DaveHelsen
    :-) in 618 it works fine thanks!!!
    Ta-da! As if by magic...
