  3. How to netlist a VHDL-AMS generic of type "time" correctly...
  • Subscribers 133
  • Views 2544
How to netlist a VHDL-AMS generic of type "time" correctly in ADE?
Eckhard Hennig
Eckhard Hennig over 7 years ago
while trying to transfer a working mixed-signal system model from Mentor Graphics SystemVision to Cadence Virtuoso/AMSDesigner I came across the following problem.
Some of the VHDL-AMS components in my system model include generic parameters of type "time", for example:
entity comparator_d is
  generic (
    delay : time := 1.0 us;
    hysteresis : voltage := 0.0
  port (
    terminal in_pos : electrical;
    terminal in_neg : electrical;
    signal output : out std_logic := '1'
end comparator_d;
I let Virtuoso (v6.1.8) create a schematic symbol from this code, then I instantiated the symbol on a new schematic with all generics left at their default values. When I netlist the design in ADE with the simulator set to "ams", the following netlist entry is created:
comparator_d #(.delay("1.0 us")) I10 (.\output ( net1 ), .in_pos( net2 ), .in_neg( net3 ));
The time value 1.0 us is passed as a string, which is not recognized as a valid time specification by the simulator.
Warning from spectre in
        `classd_models__shell_model__schematic__0x10000001':`shell_model',
        during hierarchy flattening.
    WARNING (SFE-30):
        "/home/hennig/sim/classd/shell_model/ams/config/netlist/netlist.vams"
        28: shell_model.I10: `DELAY' is not a valid parameter for an instance
        of `CLASSD_MODELS__comparator_d__behavioral__0x10000001'.  Ignored.
If I change the CDF parameters of the delay property so that the value is parsed as a number, I can change the netlist entry into something like this, ....
comparator_d #(.delay(1.0e-6)) I10 (.\output ( net1 ), .in_pos( net2 ), .in_neg( net3 ));
..., but then the simulator complains about a type mismatch.
Do you have any suggestions how to pass generics of type "time" correctly through a Verilog netlist to a VHDL-AMS component?
Eckhard
  • RolandSYBA
    RolandSYBA over 4 years ago
    I just have same problem with generics of  type time in vhdl.
    Seems this question has not yet been answered... could anyone help?
    Andrew Beckett over 4 years ago in reply to RolandSYBA
    I just tried this, in IC6.1.8-64b.500.19 (ISR19) with XCELIUM2009 (20.09-s014) (so current versions of each), and with a value on the instance of 2.0 us it gets netlisted (using UNL, which is the only option nowadays), this gets netlisted as:
    `include "disciplines.vams"
    `include "userDisciplines.vams"
    // HDL file - mylib, comparator_d, ideal.
    // Library - mylib, Cell - comparatorTB, View - schematic
    // LAST TIME SAVED: Jul 25 16:59:05 2021
    // NETLIST TIME: Jul 25 17:00:19 2021
    `worklib mylib
    `view schematic
    `timescale 1ns / 1ns
    (* cds_ams_schematic *)
    module comparatorTB ( );
    wire y;
    wire a;
    comparator_d #(.delay(2000)) I0 (.in_neg(cds_globals.\gnd! ), .in_pos( a ), .\output ( y ));
    vsource #(.type("sine"), .freq(1000000), .ampl(1)) V0 (a, cds_globals.\gnd! );
    endmodule
    As you can see, the delay gets netlisted as 2000 (an integer in timescale units). This seems to work fine... I added an assert in my architecture (based on the example above):
    assert 1>2
    report "delay is " & time'image(delay)
    severity note;
    and it prints:
    delay is 2 us
    so clearly it's working.
    What versions are you using? As far as I can see this has not been fixed recently... so I'm surprised it would be broken. Maybe the CDF is incorrect for the parameter?
