  3. how to set libmanager open automatically as ciw
  • Views 18555
sjwprc
sjwprc over 7 years ago
Is there anyway to set libmanager open automatically as ciw when cadence is starting ?
  • skillUser
    skillUser over 7 years ago
    You could put dmbOpenLibBrowser() in your .cdsinit file.
    Andrew Beckett over 7 years ago in reply to skillUser
    Lawrence, that's very naughty ;-> . That's an old 4.3.4 legacy function provided for compatibility.
    You should really use ddsOpenLibManager()
  • skillUser
    skillUser over 7 years ago in reply to Andrew Beckett
    Oops, that was the first one I found in the Finder - yes, the dds prefix function is the one I intended.  Side note, we have an alternative Library Manager so we are not using this...
