  3. How to protect the PDK files?
  • Views 16338
UUinfini
UUinfini over 7 years ago
Hello guys,
I would like to ask a question about the protection of PDK files:  display.drf, 018cmos.rul, 018cmos.tf, and so on. I have tried the ncproctect which works well with veriloga file, but not with these mentioned files. Thanks in advance.
Best regards,
UU
    Andrew Beckett over 7 years ago +1
    There's little point in encrypting the display.drf file because it doesn't contain any sensitive data, and anyway you could just dump it out again from the display resource editor. It does seem to be possible…
    There's little point in encrypting the display.drf file because it doesn't contain any sensitive data, and anyway you could just dump it out again from the display resource editor. It does seem to be possible to encrypt it using the SKILL encrypt function, but it's pointless as I said.
    The .tf file doesn't actually need to be shipped anyway because it would normally be compiled into your technology library. There's no support for encrypting it, and anyway you could simply dump the tech file from the tech.db anyway - so again, no point in encrypting it.
    The DRC rules depends on which Physical Verification tool you're using.
  • UUinfini
    UUinfini over 7 years ago in reply to Andrew Beckett
    Thanks very much, Andrew. We use Calibre for DRC and LVS, PEX. So what do you think will be useful for encryption? Thanks in advance.
    Andrew Beckett over 7 years ago in reply to UUinfini
    As far as I know, Mentor's Calibre supports encryption of the rule deck (the Cadence PVS tool certainly does). However, it's a Mentor tool (not a Cadence tool) so this is not really the best place to ask that... (I'm certainly not the best equipped to answer, because I don't have access to Calibre or the Calibre documentation).
  • UUinfini
    Thanks for your kind responses!
    Best regards,
    UUinfini
