  3. Assura LVS not running
  • Views 15985
BahaaRadi
BahaaRadi over 7 years ago
I am trying to do LVS on old design (a simple buffer), but LVS seems to be running indefinitely without displaying an error as below.
When I view the log files (shown below), it does not seem that LVS is progressing.
I am also showing the Assura LVS settings.
It does not seem to be a layout or schematic issue as the circuit has already passed LVS in the past, but LVS stopped working for some reason. I appreciate any input if anyone has experienced this before.
Thanks!
Bahaa
Note: The issue is for all designs and not just this one.
    Without more context as to what you're trying to verify, the best I can suggest is to try a more recent version of Assura. You're using a version from almost 7 years ago...
    Otherwise you should probably contact customer support via your normal support channel route (assuming you're at a university, that would be via Europractice if under the Europractice scheme, or for most of the rest of the world it's via your designated organiser at your university who should have a support account on http://support.cadence.com ). That said, support would normally expect you to move to a supported version as the first step.
