  3. Assura DRC decks writing
  • Views 15456
Jayasheel
Jayasheel over 7 years ago
Hi All,
I'm New to this forum and very happy to join you all.
I'm struggling in writing a rule deck in Assura which is already mentioned in Calibre.
The rule/syntax in Calibre 1: ACT_HORIZONTAL_EDGES = ACT ANGLE == 0
                                                   INTERNAL ACT_HORIZONTAL_EDGES > 0.048 < 0.088
The rule/syntax in Calibre 2: ACT_VERTICAL_EDGES = ACT ANGLE == 90
                                                   EXTERNAL ACT_VERTICAL_EDGES > 0 < 0.032 OPPOSITE
The Calbre two rules/syntaxes defines the horizontal width and vertical width with separate values/width and an equivalent image has been attached.Basically the derived layer is defined with an angle...
I would like to write same in assura syntax format, Please help.
