  3. ADE-XL: possible to reuse Matlab-type outputs in other scalar...
  • Views 15289
ADE-XL: possible to reuse Matlab-type outputs in other scalar outputs?
dontpanic
dontpanic over 7 years ago
Hi! Is it possible in ADE-XL to have (scalar) outputs that take as input the values returned by Matlab-type outputs ("measurements")?
For example: I have a Matlab output which calculates SNDR for an ADC taking into account calibration. Now I'd like to use that value as input to calculate a Figure-of-Merit=SNDR+10log10(Bandwidth/Power), but creating this expression in the calculator (as I would normally do if SNDR were calculated inside Virtuoso and not in Matlab) doesn't seem to work (I get in the results tab the text "eval error" for this output).
Thanks in advance for any help!
Regards, Jorge.
    Andrew Beckett over 7 years ago +1
    Hi Jorge, I didn't try this, but I suspect you probably have to use calcVal("SNDR") in the expression rather than just SNDR . Regards, Andrew.
    Hi Jorge,
    I didn't try this, but I suspect you probably have to use calcVal("SNDR") in the expression rather than just SNDR.
  • dontpanic
    dontpanic over 7 years ago in reply to Andrew Beckett
    Thanks so much Andrew, that totally solved the problem! Smiley
    Best regards, Jorge.
