  3. VerilogA Modelling for Skin Effect
  • Views 15430
MenghanSun
MenghanSun over 7 years ago
Hi all,
I'm trying to model skin effect using VerilogA. And I got the sample from  Ken's website: https://designers-guide.org/modeling/ind.pdf
Here's the model:
`include "constants.vams"
`include "disciplines.vams"
module skin_effect(p, n);
electrical p, n;
parameter real f0=1 from (0:inf);
parameter real f1=10 from (f0:inf);
parameter real r0=1 from (0:inf);
`define lumps 100
real mult, mult2, wp, wz;
real zeros[0:2*`lumps-1], poles[0:2*`lumps-1];
integer i;
    analog begin
        @(initial_step("static")) begin
            mult = pow(f1/f0, 1.0/(4*`lumps)); //May the factor in front of lumps, we can change.
            mult2 = mult*mult;
            wz = 2*`M_PI*mult*f0;
            wp = mult2*wz;
            for (i=0; i<`lumps; i=i+1) begin
                zeros[2*i] = -wz;
                zeros[2*i+1] = 0;
                poles[2*i] = -wp;
                poles[2*i+1] = 0;
                wz = mult2 * wp;
                wp = mult2 * wz;
            end
        end
        V(p,n) <+ r0*laplace_zp(I(p,n), zeros, poles);
    end
endmodule
When I simulated this, I found that both the real and imaginary parts are cut off at around 5MHz.
I experimented with lumps around, but still got the same cut off, any one can shine some light on this problem is greatly appreciated!
Thank you very much,
Menghan
    Hi Menghan,
    Wouldn't it make more sense to ask this on the Designer's Guide forums (on the site where you found the paper and model)? That way, Ken can answer this himself, since it's his model.
    I'm sure with a bit of time (and knowledge of the parameters you're using on the instance - you didn't provide that) I could investigate this, but why not just ask the author instead?
