  3. Virtuoso ADEXL VIVA Calculator Sum function?
  • Views 18752
IntelEPS
IntelEPS over 7 years ago
This might be a dumb question; however, if I want to sum 100's of signals through the VIVA calculator is there an easy way to do it? I don't see a "sum" function.
PM
    The + operator does this. Or you can use the plus(sig1 sig2 sig3 sig4) etc function (it doesn't show up in the function panel). There's no difference between doing 1+2+3+4+5 than plus(1 2 3 4 5) - they are identical. Not sure this helps that much because you need to reference all the signals somehow...
  • IntelEPS
    IntelEPS over 7 years ago in reply to Andrew Beckett
    Hi Andrew - thanks, the "plus()" function was exactly what I was trying to find.
