  3. spectre cdl
  • Views 17548
spectre cdl
nnlt
nnlt over 7 years ago
hi,AE
Can I do a simulation with the cdl netlist?  I don't want to spice in the cdl to schematic.
Thanks!
best regards,
nnlt.
    In theory, yes. CDL is effectively a superset of SPICE - most of the additions are implemented using SPICE comments. However, there may be some differences:
    1. CDL nowadays in Physical Verification tools allows connections by name rather than just by order - this isn't (as far as I know - I've not checked recently) supported in Spectre
    2. The instances may have a subtype specified rather than the model name - so it may need adapting before you can simulate it
    3. Some components (such as three-terminal resistors) may connect the extra terminal by a parameter $SUB - and that won't be honoured.
    4. Usually the CDL doesn't contain parasitic info such as AD AS PD PS etc - so it may not model everything it should.
    So it boils down to how close the CDL is to SPICE.
  • nnlt
    nnlt over 7 years ago in reply to Andrew Beckett
    thanks andrew
