  3. ADE error when I try to load *.VCD file
  • Views 18187
Nhumai
Nhumai over 7 years ago
Hi ,
i simvision to dump out a *.vcd file and try to use that *.vcd file as an input  to my ADE/spectre simulation.
I have 2 files
rowdecode.vcd which dumped about by simvision
rowdecode.vcd_infor I create it
both file are attached.
I don't know why when I try to load them in ADE and run I got the error like
ERROR (OSSGLD-18): The command character after '[' in the NLP expression '[10:0] $end ' is not a valid character. The command character is the first character after '[' in the NLP expression. It must be '?', '!', '#', '$', 'n', '@', '.', '~' or '+'. Enter a valid character as the command character.
               si: simin did not complete successfully.
ERROR (ADE-3016): Could not map schematic names in the stimulus file /import/proj4/ca18/OA/projects/sbf303/work_libs/e373035/cds/simulation/stimulus/rowdecode/rowdecode.vcd
        to the target simulator.
      ...unsuccessful.
Anyone know how to fix it please let me know
thanks
Nhumai
rowdecode.vcd.txt
Fullscreen rowdecode.vcd_infor.txt Download
From:	Nhumai T Le <e373035@sbfsr072367.orl.lmco.com>
Sent:	Wednesday, June 26, 2019 3:44 PM
To:	Le, Nhumai T (US)
*This command is used to match the input and output vector syntax between VCD file and spice netlist.
*syntax: .alias VCD_bus_syntax signal_bus_syntax
.alias ra[*] ra<*>
*scope to take care of signals present in lower level hierarchy.In this testcase i have just placed
buffertest as it contains top-level signals.
.scope tb_digleft_asic
* .in, .out and .bi are used to define specified bus as input,output and bi-directional signals as is netlist.
.in clr prstsh ra[10:0] row_valid vrefl_m
*These parameters define used when you to converting digital vector to analog signal.
*These specify the rise time, fall time, logical input high, logical input low,logic output high, logic output
low.
.trise  100
.tfall  100
.vih    3.3
.vil    0.0
.voh    3.3
.vol    0.0
*This sets the reference to time t=0 (where you grabbed the VCD signals from) .tdelay 0
*in addition to this if you have specified output vectors in VCD file then you need to "chkwindow"
parameter to check output signal in the specified window range.
    My guess is that you used the wrong field to specify the files - I think you've used the Setup->Simulation Files and then used the Stimulus Files field on the first tab (Paths/Files) whereas you should have used these fields on the Vector Files tab:
    I got exactly the same error you did if I put these files in the Stimulus File field - that's incorrect usage, as that expects a spectre syntax file, not a VCD file.
