  3. The checks/Asserts in the ADE XL
  • Views 2893
nnlt
nnlt over 7 years ago
Dear Andrew,
I use the checks/asserts function in the ade xl to do the static HighZ Node Chenk, if I choose the Spectre in the simulaiton performance mode the violations in the results are 0, if  I choose the APS in the simulaiton performance mode the violations in the results are 4 and these results are right. why?
thanks!
Best Regards,
nnlt.
    From "spectre -h static_highz":
    Static HighZ Node Check
    Reports the nodes that do not have any possible conducting path to a DC power supply
    or ground.
    The results are written to the static.xml file, which can be viewed in a Web browser.
    This check is supported only by XPS and APS.
