  3. Installation procedure of cadence virtuoso + MMSIM + assura...
  • Views 19860
Installation procedure of cadence virtuoso + MMSIM + assura on centos
abdoboua
abdoboua over 7 years ago
can you please give me a well described setup guide for cadence IC 06.17.700 virtuoso + MMSIM 15.10.257 + assura 615 on centos
    Andrew Beckett over 7 years ago +1
    For a start, none of these are officially supported on CentOS, so there won't be a guide associated with that. Also, this mix of versions is not a good combination - for a start, you'd need ASSURA41…
    Also, this mix of versions is not a good combination - for a start, you'd need ASSURA41-617 (not 615). It's also a good idea to have a newer SPECTRE version (SPECTRE is the new release stream replacing MMSIM). We've had 3 major releases of SPECTRE since MMSIM151.
    In general you need to install these using InstallScape (which can be downloaded on downloads.cadence.com), with each in a separate directory. You'd then do:
    set path = ($ICHOME/tools/bin $ICHOME/tools/dfII/bin $MMSIMHOME/bin $ASSURAHOME/bin $path)
    (if using csh). There's no need to have an environment variable for ICHOME and MMSIMHOME (the tools just need to be in  your UNIX path), but $ASSURAHOME must be set as a UNIX environment variable. You'd also normally have $CDS_LIC_FILE set (again, a UNIX environment variable) pointing to your license server - e.g. 5280@licservername
    Hard to know how much to include without knowing where you are starting from. I'd suggest you contact customer support, or if you're a University then your university program contact (such as Europractice).
