  3. Star RC Extraction Simulation
  • Views 18694
ARWAH
ARWAH over 7 years ago
Dear All,
I am new in Digital IC Designing, i want to run Star RC Extraction Simulation.
Please share tutorial or relevant helping material.
Waseem
    Andrew Beckett over 7 years ago +1
    Hi Waseem, First of all, Star RC is a Synopsys product, and not a Cadence product, so asking here is not that likely to give you the answer you desire. Also, you say you're doing Digital IC Design; unless…
    Hi Waseem,
    First of all, Star RC is a Synopsys product, and not a Cadence product, so asking here is not that likely to give you the answer you desire. Also, you say you're doing Digital IC Design; unless you are doing Custom digital (i.e. transistor level digital design), this forum is unlikely to be your best place for help anyway. If you are dealing with digital implementation tools (physical synthesis, digital place and route, extraction, timing analysis, power etc - using Cadence tools), then the Digital Implementation forum is going to be the place for you. If it's about logic design then it would be the Logic Design forum.
    However, regardless of what type of design you're doing, you would be better off asking about StarRC on a Synopsys forum (assuming they have them - I've not checked recently) or Synopsys customer support.
  • ARWAH
    ARWAH over 7 years ago in reply to Andrew Beckett
    Thank you very much for your cooperation. your comment is very helpful for me.
