  3. Error when try to use ADE simulator to initialize
  • Subscribers 133
  • Views 18476
Ning08
Ning08 over 7 years ago
Hello there,
Before last weekend, everything was fine. The error came with no indication. I tried to modify the cds.lib, .cdsenv and .cdsinit. The error just always there. The problem makes ADE cannot initialize the schematic information, even I load the state manually still not work. I do not know what is the problem. I check the file and file path, they are all correct. My cadence is IC 5.1.41. Thank you very much. It bothers me for almost one week.
Error (cif): 'error while processing path' cifNormalizePathSorta : /tools/cadence/Assura/AV41/lnx86/tools/assura/etc/avtech/avTech.
    There are some hints related to this message in this support article: How to verify the correctness of the Assura environment configuration after installation if Assura menu does not appear in the layout
    Specifically check that the version of Assura you're running is one intended for IC5141 (you should be able to see this from the results of running (at the UNIX prompt): assura -V
    Then remove the DEFINE for avTech in the cds.lib and add:
    DEFINE avTech $ASSURAHOME/tools/assura/etc/avtech/avTech
    That said, I'd be very surprised if this error has anything to do with ADE not being able to initialise. How are you starting ADE? Can you post the CDS.log file from a session where you are just starting and trying to start ADE in your normal way? This would help identify if anything untoward is happening.
  • Ning08
    Ning08 over 7 years ago in reply to Andrew Beckett
    Hello sir,
    I am also wondering about this. There are also some other errors but that is the first one. I attached the cds.log below.
    Fullscreen CDS.log Download
    \o Program:		@(#)$CDS: icfb.exe version 5.1.0 10/28/2008 10:23 (cicln03) $
    \o Hierarchy:		/CMC/tools/cadence/IC5141USR6_lnx86/tools.lnx86/dfII/
    \o Sub version:		sub-version 5.10.41_USR6.127.29 (32-bit addresses)
    \o Host name (type):	king.vlsi.ee.dal.ca (x86_64)
    \o Operating system:	Linux 2.6.18-92.1.6.el5 #1 SMP Wed Jun 25 12:38:37 EDT 2008
    \o X display name:	localhost:10.0
    \o X server:		Colin Harrison
    \o Depth of Visual (Root):	24 (24)
    \o Number of Planes Used:	24
    \o X version:		11.0 (vendor release 60900031)
    \o Window Manager:	other
    \o User Name:		ngaoudi
    \o Working Directory:	king.vlsi.ee.dal.ca:/vlsihome/grads/ElSankari/ngaoudi/cmos65nm
    \o Process Id:		395
    \o
    \o COPYRIGHT � 1992-2008  CADENCE DESIGN SYSTEMS INC.  ALL RIGHTS RESERVED.
    \o           � 1992-2008  UNIX SYSTEMS Laboratories INC.,
    \o                          Reproduced with permission.
    \o
    \o This Cadence Design Systems program and online documentation are
    \o proprietary/confidential information and may be disclosed/used only
    \o as authorized in a license agreement controlling such use and disclosure.
    \o
    \o           RESTRICTED RIGHTS NOTICE (SHORT FORM)
    \o Use/reproduction/disclosure is subject to restriction
    \o set forth at FAR 1252.227-19 or its equivalent.
    \p >
    \o 8-bit PseudoColor Visual is not available (default Visual option).
    \o Using 24-bit TrueColor Visual.
    \o The program xdpyinfo can be used to verify the Visuals available
    \o for your display.
    \o Loading PRshare.cxt
    \o Loading LVS.cxt
    \o Loading layerProc.cxt
    \o Loading ams.cxt
    \o Loading acv.cxt
    \o Loading auCore.cxt
    \o Loading schView.cxt
    \o Loading selectSv.cxt
    \o Loading seismic.cxt
    \o
    \o function kuDisplayLayers redefined
    \o function showLayerList redefined
    \o function showMarkersList redefined
    \o function hideAllLayersExceptThisList redefined
    \o function setLayerAndRedraw redefined
    \o function kuDisplayMetalLayers redefined
    \o function hideImplantLayers redefined
    \o function hideExtraLayers redefined
    \o function hidePadLayers redefined
    \o function layerListForDisplay redefined
    \o function EnsureLayersDoNotAppear redefined
    \o function LppExistsInTechFile redefined
    \o function ReadLswConfigFile redefined
    \o function GetVisibleLayers redefined
    \o function Append redefined
    \e *Error* load: can't access file - "/vlsihome/grads/ElSankari/ngaoudi/artist_files/SKILL_SCRIPTS/32n/kuCreateExcludePolygone.il"
    \o //
    \o //  Calibre Skill Interface * (v2009.4_31.27) *
    \o //
    \o //                 Copyright Mentor Graphics Corporation 2005
    \o //                             All Rights Reserved.
    \o //         THIS WORK CONTAINS TRADE SECRET AND PROPRIETARY INFORMATION
    \o //            WHICH IS THE PROPERTY OF MENTOR GRAPHICS CORPORATION
    \o //              OR ITS LICENSORS AND IS SUBJECT TO LICENSE TERMS.
    \o //
    \o //
    \i ddsWhatsNew()
    \p >
    \a hiResizeWindow(window(1) list(1212:-937 1937:-776))
    \r t
    \r t
    \a hiResizeWindow(window(2) list(1346:-60 1936:440))
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \a ddsOpenLibManager()
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \i ddsServOpen("CT_DSM_project" "encoder_4_adc" "schematic" "edit")
    \o Error (cif): 'error while processing path' cifNormalizePathSorta : /tools/cadence/Assura/AV41/lnx86/tools/assura/etc/avtech/avTech.
    \o
    \w *WARNING* LIB avTech from File /vlsihome/grads/ElSankari/ngaoudi/cmos65nm/cds.lib Line 37 redefines
    \w LIB avTech from File /CMC/kits/tsmc_65nm/CRN65GP/TN65CMSP018K1_V1.0C/cds.lib
    \w Insert UNDEFINE avTech
    \w before DEFINE avTech
    \w     in /vlsihome/grads/ElSankari/ngaoudi/cmos65nm/cds.lib
    \w Or remove or comment out DEFINE avTech
    \w     in /CMC/kits/tsmc_65nm/CRN65GP/TN65CMSP018K1_V1.0C/cds.lib
    \w to suppress this warning message.
    \o Initializing from libInit.il for library tsmcN65...
    \o    --  tsmcPdkParamTable.il
    \o    --  tsmcN65_updateCDFs.il
    \o    --  tsmc_esti.ile
    \o    --  /CMC/kits/tsmc_65nm/CRN65GP/TN65CMSP018K1_V1.0C/tsmcN65/../skill/tsmcN65gp_v1d0c.cxt
    \o    --  /CMC/kits/tsmc_65nm/CRN65GP/TN65CMSP018K1_V1.0C/tsmcN65/../skill/tsmcN65_newAMS.cxt
    \o    --  /CMC/kits/tsmc_65nm/CRN65GP/TN65CMSP018K1_V1.0C/tsmcN65/../skill/tsmcN65_newRTMOM.cxt
    \o    --  /CMC/kits/tsmc_65nm/CRN65GP/TN65CMSP018K1_V1.0C/tsmcN65/../skill/tsmcN65GP_v1d0.cxt
    \o    --  tsmcN65_newRTMOM.cxt
    \w *WARNING* (loadContext): context tsmcN65_Patc already loaded
    \o    --  tif_tcf_crn65gp_v1.0a.cxt
    \o    --  tsmcN65Tool.cxt
    \o    --  tsmcN65GP_v1d0.cxt
    \w *WARNING* (loadContext): context tsmcN65GP_v1 already loaded
    \o    --  tsmcN65gp_v1d0c.cxt
    \w *WARNING* (loadContext): context tsmcN65gp_v1 already loaded
    \o    --  tsmcN65_newAMS.cxt
    \w *WARNING* (loadContext): context tsmcN65_v1d3 already loaded
    \o    --  tsmcN65.cxt
    \o Loading Working place Display File '~/cmos65nm/display.drf'
    \o Loading awv.cxt
    \o Loading oasis.cxt
    \o Loading analog.cxt
    \o Loading asimenv.cxt
    \o Loading spectrei.cxt
    \o Loading hspiceD.cxt
    \o Loading spectreinl.cxt
    \o Loading UltraSim.cxt
    \o Loading AMS.cxt
    \o Loading hspicei.cxt
    \o function tsmcCdfFormInitCB redefined
    \o Loading schematic.cxt
    \o Loading lo.cxt
    \o
    \o (icfb) Syncing library list with the Library Manager.
    \i ddUpdateLibList()
    \o
    \a hiResizeWindow(window(3) list(256:-80 1156:610))
    \r t
    \r t
    \r t
    \r t
    \o Loading alvs.cxt
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \a deInstallApp(getCurrentWindow() "analogArtist-Schematic")
    \o Loading simui.cxt
    \o Failure to get license
    \o *Info*    Dumping diagnostic information ....
    \r t
    \r t
    \r t
    \r t
    \o *Error*   Unable to establish connection with WaveScan. For further
    \o           assistance, contact Cadence Customer Support with the
    \o           diagnostic information available in the log file. You can
    \o           use AWD as your waveform viewer until the problem is
    \o           resolved.
    \r t
    \r t
    \r t
    \r t
    \o           resolved.
    \r t
    \r t
    \r t
    \r t
    \a hiResizeWindow(window(4) list(18:14 596:386))
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \w *WARNING* Unable to create simulation session.
    \w
    \r t
    \r t
    \r t
    \r t
    \r t
    \w *WARNING* A check-out of the Artist simulation environment feature failed.
    \w Suggestion: [1] Check your license file.
    \w 	    [2] Ask a current user of the feature to exit the Artist simulation environment.
    \w
    \r t
    \r t
    \r t
    \r t
    \r t
    \w *WARNING* Unable to annotate simulation results.
    \w
    \r t
    \r t
    \r t
    \r t
    \r t
    \w
    \r t
    \r t
    \r t
    \r t
    \r t
    \a hiResizeWindow(window(4) list(250:22 828:394))
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \a sevOpenSchematic('sevSession1)
    \o
    \p >
    \o
    \o
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \a hiiSetCurrentForm('sevDesignForm1)
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \a sevDesignForm1->lib->value = "CT_DSM_project"
    \r "CT_DSM_project"
    \r t
    \r t
    \r t
    \r t
    \a sevDesignForm1->cell->value = '("encoder_4_adc" )
    \r ("encoder_4_adc")
    \a hiFormDone(sevDesignForm1)
    \r t
    \r t
    \r t
    \r t
    \r t
    \w
    \r t
    \r t
    \r t
    \r t
    \r t
    \w
    \r t
    \r nil
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    \r t
    Andrew Beckett over 6 years ago in reply to Ning08
    Apologies for the late response, but this appears to be nothing to do with Assura but more to do with your license setup. It says:
    Perhaps  your licenses have expired? Perhaps you just are not pointing at the correct license server?
