  3. Device checking output in Spectre
  • Views 16157
nicola91it
nicola91it over 7 years ago
Hi all,
I've got a model file .scs where I've set all rules for checking the maximum voltage across each terminal of my transistors. For example, each line is like the following:
Assert_name assert sub=my_sub mod=my_mod expr=my_expr message=my_message level=warning
Then, in ADEL I include this file in model libraries and device checking is performed when I run simualtions. To output the results, I've found
Simulatiion->options->analog->check,
where I set dochecklimit=yes, and I specify the file where I want the report to be saved in checklimitdest.
Next are my questions:
- When I open the output file, it just displays different violations reporting the instance and the type of violation. Is It possible to have a more readable report that lists, for example, instance, violation, intant of time when violation occured, duration, and magnitude of violation?
-in some technoligies I've noticed that the simulator displays warning messages in the CIW because it simply reads some maximum ratings in the model files of transistors (so, a file containing different asserts is not needed here). May I know how Spectre knows how to output these warning without any assert?
Hope it's all clear (unfortuantely, cannot report technolgies that are bring used).
Thank you in advance.
Nicola
