  3. Virtuoso_Schematic_Editor_XL License Checkout Failure IC...
  • Subscribers 133
  • Views 22408
Virtuoso_Schematic_Editor_XL License Checkout Failure IC 6.1.8
FormerMember
FormerMember over 7 years ago
When using Library Manager new cellview in IC 6.1.5, it first tries to checkout Virtuoso_Schematic_Editor_L, fails, and then successfully checks out Virtuoso_Schematic_Editor_XL
When using trying the same Library Manger new cellview in IC 6.1.8, it first tries to checkout Virtuoso_Schematic_Editor_L, fails, then tries to checkout Virtuoso_Schematic_Editor_XL, and fails again.
The exact error message is:
ERROR (ELI-00111) Failed to check out license 'Virtuoso_Schematic_Editor_L'.
ERROR (ELI-00111) Failed to check out license 'Virtuoso_Schematic_Editor_XL'.
(DEBASE-100019): (deLicense-5) The open operation has been cancelled because a valid license for Schematics could not be checked out.
I have verified in the license file that we fo have a Virtuoso_Schematic_Editor_XL license.
Any ideas?
Thanks.
M. D.
    Two things to check:
    1. Does the version number on the FEATURE line for Virtuoso_Schematic_Editor_XL have 6.18 as the version number?
    2. Are you using up to date lmgrd/cdslmd versions (such as those shipped with IC618 or from the latest Lic_Config_Utils release)?
    In general though, this is best handled through customer support.
