  3. Dependent test-bench with different temperature simulat...
  • Views 14670
Dependent test-bench with different temperature simulation
abhishekMXL
abhishekMXL over 7 years ago
Here is what my requirement is,
1) First test-bench is for trimming the circuit. ( only @ 27C )
2) In second test-bench, Trimming code obtained from first test bench , should be used  but at other temperature ( eg 125C)
I am using calcVal to get the trim code from first test-bench. Simulation corner is defined based on other temperature( 125C)  as it is the worst case corner for me. So whenever I am doing the simulation, the first trimming simulation is also happening at 125C, which is understandable.
Is there a way in GUI for first test bench to always take 27C and when 2nd ( the dependent ) test-bench is running , it should run with the temperature mentioned in the corner set up.
Any help is highly appreciated.
Abhishek
