  3. print schematics to pdf file
  • Views 19143
bid75
bid75 over 7 years ago
I am using following .cdsplotinit file
Encapsulated PostScript|Encapsulated PostScript: \
        :manufacturer=Adobe: \
        :type=epsf: \
        :resolution#300: \
        :maximumPages#1: \
        :paperSize="5x5 inches" 1500 1500: \
        :paperSize="8x8 inches" 2400 2400: \
        :paperSize="Unlimited" 72000 72000:
However when I print the schematic view to pdf, the fonts of the annotated text are thick and unreadable. circuit symbols come out fine.
Are there any standard settings to get out good quality schematic pdfs?
Bhavin
    Hi Bhavin,
    Not sure why you're getting the text affected this way, but one possibility is to add:
    :residentFonts: \
    (whether you need the backslash depends on whether it's within the block or at the end of course). This will tell it to use courier font for text rather than drawing the text as lines. If you want control over the font, you could also use:
    :StickFont=/Helvetica: \
  • bid75
    bid75 over 7 years ago in reply to Andrew Beckett
    That didn't help. Adding following lines to .cdsplotinit helped to fix this problem.
            :resolution#1000: \
            :paperSize="A" 8000 10500 250 250: \
            :paperSize="B" 10500 16500 250 250: \
    The following post helped.
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/14915/cadence-to-hierarchical-pdf
    Rgds
    Bhavin
