  3. mdl to .measure conversion
  • Views 16265
Murtuza1981
Murtuza1981 over 7 years ago
Hi
I need to convert following spectremdl statement into spice (.measure) format. Help needed.
export real tpCs = cross( sig=trim(sig=V(cs), from=2n, to=7n), dir='cross, thresh=(((v(cs)@ 2n) > (10*vdd/100)) ? ((100-10)*vdd/100) : 10*vdd/100)))
    Why do you need to do that? Spectre can use .measure, but it's better to use the native MDL expression if you can.
    .MEASURE is honoured for compatibility reasons with other simulators, but it's not the first choice for spectre. Perhaps you're using another simulator?
  • Murtuza1981
    Murtuza1981 over 7 years ago in reply to Andrew Beckett
    we are planning to make our measurements tool independent. .measure command is supported by all simulator.
    Andrew Beckett over 7 years ago in reply to Murtuza1981
    I'm not that familiar with .MEASURE (we don't document it as part of the spectre documentation), but I think it would be something like:
    .MEASURE tran cs_at_2n FIND V(cs) AT=2n
    .MEASURE tran tp2cs WHEN V(cs)='((cs_at_2n > (10*vdd/100)) ? ((100-10)*vdd/100) : 10*vdd/100)' CROSS=1 FROM=2n TO=7n
  • Murtuza1981
    Thanks, Andrew. I tried and it worked.
