  3. Monte Carlo Variation in Hierarchical Vs Flat Netlist
  • Views 16959
jp2o
jp2o over 7 years ago
I am a user of Virtuoso Assembler mainly Spectre Version 16.1.0.479.isr9 32bit -- 7 Sep 2017.
I am wondering what the effects of the netlist type (flat, hierarchical) on the application of variation are. For example, if I have created a unit cell X, and now plan to instantiate X 100 times within a schematic, is the variation applied to the sub-circuit, to the instance, or both? If there are differences in the application of the variation, is there a way to control it in the simulation, by switch or by forcing a flat netlist?
Also, a similar question, what assumptions are made by the monte carlo engine when using m factors on transistors, vs number of fingers?
Justin
    Andrew Beckett over 7 years ago +2
    Hi Justin, In general, the structure of the design hierarchy doesn't impact the results - whether it is flat or hierarchical. There are some requirements for mismatch that subckt models are used (see…
    Hi Justin,
    In general, the structure of the design hierarchy doesn't impact the results - whether it is flat or hierarchical. There are some requirements for mismatch that subckt models are used (see Recommended Spectre Monte Carlo modeling methodology for some details), but that's not something you'd impact by your design. I don't see any benefit in forcing a flat netlist (actually, there's no capability in ADE to force a flat netlist anyway, so doing that would be hard and rather pointless).
    Now this is related to mismatch modelling - process modelling is independent of the instances, whereas mismatch modelling is applied to the instances of these subckt models.
    For handling of m-factor, that may depend on how the foundry has modelled the m-factor effect. Commonly 100% correlation is assumed which isn't that realistic (see article Monte Carlo should take m into account for mismatch which describes one way it could be modelled and also How does spectre apply correlation between m-factor devices during Monte Carlo simulation? which describes an option to get spectre to adjust the correlation to be zero - i.e. take it into account).
    • Vote Up +2 Vote Down
  • jp2o
    jp2o over 7 years ago in reply to Andrew Beckett
    Thank you Andrew, these articles were very helpful in understanding the correlation of device instances arrayed vs mfactor. https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000tjjEEAQ&pageName=ArticleContent informs as to how to set nullmfactorcorrelation for adexl but I tried setting the environment variable and then running mc in assembler and it did not pick it up.The setting I used is:
    envSetVal("adexl.monte" "additionalNetlistOptions" 'string "nullmfactorcorrelation=yes")
    Is there an equivalent for assembler or is there a gui option to set this?
    Justin
    Andrew Beckett over 7 years ago in reply to jp2o
    Hi Justin,
    You'll need to put this envSetVal in your .cdsinit because (usually) the netlist is created in a background process and so will not pick up any changes in the CIW.
