  3. Monte carlo run stopped because no statistical data generated...
  • Views 19699
Monte carlo run stopped because no statistical data generated for the test
Iaf22
Iaf22 over 7 years ago
Hello, i'm trying to make a monte carlo simulation of a transient to make a histogram of the power consumption at low temperature. I have set the transient simulation to 10 us and put an saved all signals to get the power saved in the results. Then i generated an expression to show the average value of the power during this period. After running the simulation it starts running and a fter a few minutes it shows this error:
ADEXL-5052: Monte carlo run stopped because no statistical data generated for the test. I don't know what should i change in the simulation. here are some photos attached of the setup
    Most likely you are not pointing at model files which have statistics blocks and so don't define the variation.
  • Iaf22
    Iaf22 over 7 years ago in reply to Andrew Beckett
    Actually the problem was somehow a space problem as when i decreased the number of jobs to 10 instead of 40 or 50 it worked fine! Is there any explanation for that?
    Andrew Beckett over 7 years ago in reply to Iaf22
    That's very surprising. I don't think I've ever come across that before.
