  3. how to custom abutted devices' poly to contact distance
  • Subscribers 133
  • Views 3133
DavidLou
DavidLou over 7 years ago
Hello experts,
I have quite a lot abutted devices in a long row.  I'd like to expand the poly to contact distance so that they can pitch-match with other rows.
I have an example snapshot here to illustrate with larger scale than the expansion I'm looking for. the first row is where I wish I can expand the Poly and Contact spacing so that in the end the all the devices in both rows are aligned, without actually make the devices in first row bigger/wider. I want them still be abutted to avoid edge effect.
is there someway I can control such spacing when abutting devices?
IC6.1.7-64b.500.21
thanks a lot,
David
    Hi David,
    Whether you can do this depends on whether the devices have a parameter to control increasing the poly to contact spacing, and whether they honour that during abutment. That's a function of whatever PDK you're using, not a general capability. In essence, the abutment capability is pretty technology agnostic; it's up to the PDK and the devices themselves as to precisely what happens when an abutment event occurs (i.e. when pin figures which have abutment properties on them are overlapped).
  • DavidLou
    DavidLou over 6 years ago in reply to Andrew Beckett
    thanks Andrew, fine, I take that as no then. there are not many cdf parameters we can play with from the cells....
    Andrew Beckett over 6 years ago in reply to DavidLou
    It might be yes, it might be no - I can't say. It's not something that is under Virtuoso's control, but a function of the however the PDK has been implemented.
    Sometimes there are hidden parameters which control this kind of thing in some PDKs - you might be wise to ask the foundry.
