  3. OP annotate problem with Config based sim
  • Subscribers 133
  • Views 14087
DavidLou
DavidLou over 6 years ago
hello experts,
Seems like I'm running into a corner case that (I might be confusing in earlier post so clean up a bit):
1. if I run ADE or Ocean with schematic as top, I can annotate the corresponding schematics, with both terminal Voltage and OP;
2. if I run ADE or Ocean with Config based design as top (e.g., a few sub-blocks as behavioral and/or another few as transistor level), I can only annotate terminal Voltage but no more OP ;
so is it possible to annotate OP for Config based sim?
    IC6.1.7-64b.500.21
thanks a lot,
David
